Inca una electrica, FIT EV...
Ieri Honda a lansat un model din clasa mica hybrid, FIT EV.
Honda Fit EV
The Fit EV is designed to meet the daily driving needs of the average metropolitan commuter and utilizes the same 5-passenger layout found in the popular Fit hatchback. When the Fit EV production model is introduced, it will be powered by a lithium-ion battery and coaxial electric motor.
The high-density motor, derived from the FCX Clarity fuel cell electric vehicle, delivers excellent efficiency and power while remaining quiet at high speeds. The Fit EV will have a top speed of 90 mph.
The Fit EV will achieve an estimated 100-mile driving range per charge using the US EPA LA4* city cycle (70 miles when applying EPA's adjustment factor). Driving range can be maximized by use of an innovative 3-mode electric drive system, adapted from the 2011 Honda CR-Z sport hybrid. The system allows the driver to select between Econ, Normal, and Sport to instantly and seamlessly change the driving experience to maximize efficiency or improve acceleration. While in Econ mode, practical driving range can increase by as much as 17 percent, compared to driving in Normal mode, and up to 25 percent compared to driving in Sport mode. Acceleration improves significantly when in Sport mode, generating performance similar to a vehicle equipped with a 2.0-liter gasoline engine.
In addition to the 3-mode E-Drive system, the Fit EV will include several interactive coaching systems to assist the driver in maximizing battery range.
A special meter display advises the driver when to shut
Restul AICI
Eu sunt curios de un singur lucru, cat costa un set noi de baterii, daca una Li-Ion pentru un laptop Lenovo este ~100€ Confused
Din ce vad eu acolo, e un full electric, nu hybrid cum spune titlul articolului. Mai jos zice ceva de un plug-in hybrid, dar nu pe Fit-ul asta. Daca CR-Z'ul il mai inteleg (ca am mers cu el) pe Fit-ul asta nu-l pricep si pace...
