Sign in
Create account
Login
Username:
Password:
Lost Password?
Remember me
Home
Forums
Search
Members
Calendar
Help
HondaTalk
GARAJ
Motor/Alimentare/ECU
Rateuri in admisie
Rateuri in admisie
Valyi93
1000 rpm
Thanks Received:
0
in 0 posts
04-01-2014, 18:56
Am observa ca imi da rateuri in admisie dar si pe evacuare cand incep sa accelerez mai tare de la 2500 3000 rpm. Nu dar mereu, maxim 2-3 pe zi cand are ea chef. De la ce poate fi ?
Find
7000 rpm
Thanks Received:
81
in 73 posts
#2
07-01-2014, 16:11
(This post was last modified: 07-01-2014, 16:12 by
dar cand are chef, maxim ce poate fi, mereu, nu ???
Find
Valyi93
1000 rpm
Thanks Received:
0
in 0 posts
#3
07-01-2014, 23:02
vroiam sa zic ca Nu DA mereu, imi da maxim 2-3 pe zi cand are ea chef. De la ce poate fi ?
si ieri si azi am mers cu ea si nu a dat deloc , ciudat ...
Find
On the limiter!
Thanks Received:
114
in 106 posts
#4
07-01-2014, 23:13
incerca sa vezi daca da si in frana de motor la retrogradare + spritz in pedala inainte de lasarea ambreiajului.
Invidia
Injen
Weapon
R
Eibach
Drag Wheels
Skunk2
Magnat
Find
Valyi93
1000 rpm
Thanks Received:
0
in 0 posts
#5
08-01-2014, 03:16
o sa incerc . in caz da imi da ce se intampla ?
Find
On the limiter!
Thanks Received:
114
in 106 posts
#6
08-01-2014, 10:08
face poc, ce sa se intample?
poate sa insemne amestec bogat.
Invidia
Injen
Weapon
R
Eibach
Drag Wheels
Skunk2
Magnat
Find
7000 rpm
Thanks Received:
81
in 73 posts
#7
08-01-2014, 11:07
revizuieste tot ce tine de aprindere si vezi sa fie bine pusa distributia la punct .
Find
On the limiter!
Thanks Received:
114
in 106 posts
#8
08-01-2014, 14:19
aia era urmatoarea faza, daca in frana de motor nu pusca, ma gandeam pa distributie.
Invidia
Injen
Weapon
R
Eibach
Drag Wheels
Skunk2
Magnat
Find
6000rpm
Thanks Received:
65
in 53 posts
#9
08-01-2014, 16:37
spritzu' ala era cu vin alb , nu?
Find
On the limiter!
Thanks Received:
114
in 106 posts
#10
08-01-2014, 19:45
da, si cu sifon
Invidia
Injen
Weapon
R
Eibach
Drag Wheels
Skunk2
Magnat
Find
6000rpm
Thanks Received:
65
in 53 posts
#11
08-01-2014, 20:36
gut gut!
Find
Powered By
MyBB
, © 2002-2022
MyBB Group
HondaTalk.ro
© 2010-2022 - All Rights Reserved.
Linear Mode
Threaded Mode
View a Printable Version
Subscribe to this thread
Add Poll to this thread
Send thread to a friend
