jante nsx
#31
Mare atentie la offset (ET). Cu ET15 o sa iti iasa in afara si spate si fata ca dracu.
STOCK size
Offset (1991 - 2001) 55 mm front, 60 mm rear
Offset (2002+) 55 mm front, 56 mm rear
Center bore (all years) 70(.1) mm front, 64(.1) mm rear
Bolt pattern (all years) 5-bolt pattern, 114.3 mm bolt circle
Vezi ce zic baietii aici, daca le atinge sau nu si ce offseturi si latime de cauciuc folosesc.
http://www.nsxprime.com/forum/showthread...heel-guide!
am luat pana la urma niste Enkei rpf1
Front: 17X8.0, +45 offset, 7kg
Rear: 18X10.0, +38 offset, 8 kg
Ar trebui sa intre de minune pe masina.
P.S. Auzi, la tine nu e recesiune Icon_razz
Sent from my Nexus 4 using Tapatalk 4 Beta
na ca dupa aproape 1 an m-am scapat si de astea
Powered By MyBB, © 2002-2021 MyBB Group.
HondaTalk.ro © 2010-2021 - All Rights Reserved.
