Honda Stream 2008 RN6
#16
Si cred ca am gasit ce cautam, daca nu ma insel acelasi produs a folosit si Laux la Civic.
https://www.deadening.co.uk/products/sil...olume-pack
Trebuie sa masor sa vedem cat trebuie sa cumpar.  Ma gandeam sa pun 2mm in usi si 4mm pe oalele la roti, hayon, podea portbagaj  Confused
Quote:AN EXCELLENT PRODUCT FOR AUTOMOTIVE SOUND DEADENING
This stuff is pretty much the best sound deadening I have used so far! My current car and my previous 4 cars have always ended up having sound deadening work done on them as I'm a bit fussy when it comes to aural build quality and quietness on the road. I've used many products before including Dynamat, Second Skin and good old Flashing tape! This is by far the best in adhesion and best at getting rid of unwanted noise. Very happy with the outcome and more than impressed with the ease of use of this product. Bonnet, Doors and Bootlid, Underside of rear bench and boot floor are all done! Tempted to remove the roof liner and do the roof too now!
AS GOOD AS THE 'BIG BRANDS'
I've used this alongside more expensive products from the established market leaders and despite my initial reluctance to admit it, this stuff from Silent Coat is just as good. IF (and that's a big if)' it does fall short in terms of performance figures, it certainly isn't noticeable to the human ear. Mass loading is not an exacting science, it is purely adding mass to an object to reduce unwanted vibration, the trick is to do this whilst keeping the weight to minimum. I have deduced that there is very little speaker performance to be gained by covering more than 60-65% of the surface area of a panel with Silent Coat so the 0-60mph figures aren't impacted noticeably. I've fitted it to a particular cars doors, roof and floor and found it very easy to work with. The product is easy to cut with a pair of kitchen scissors and adheres very well to a clean surface. The backing peels off nicely and there is no discernible smell. So, as hard as it is to admit, I've probably been wasting money on the more expensive products. There are probably fanboys out there who may disagree but for myself who generally doesn't get caught up with labels and branding blurb, this is now my product of choice.
3 kile/m2 Icon_biggrin
Îi mult sau puțin?
pt stream nu Icon_biggrin
6kg e mai ușor decât subwoofer-ul tău
sub-ul meu s-a vandut de mult Icon_biggrin
Mă gândeam eu de ce ai "curajul" să comentezi de greutate Icon_biggrin
(03-07-2017, 22:33)yulasinio Wrote: Mersi fain Traiane. Dacă ajungi pe aici poți să-ți iei una cu tine Icon_smile când ai în plan să te duci pe UK?
Nush mane, habar nu am, anul asta nu cred că ajung.
Astăzi am inspectat un pic mașina la suspensie că troncăne ceva pe partea stângă când dau in gropi. Totul pare OK, știe cineva dacă pe civic este rulment în capul telescopului?
Altă întrebare ce naiba e senzorul ăla legat de brațul de jos?[Image: 9d74bee77501db812154a9cc2a2a8e37.jpg]
toate au rulment altfel nu se roteste. de obicei sunt rulmenti "plati" da nu cred ca de la el e problema.
senzorul e de la xenoane , regleaza nivelul.
Mersi Tomi.
Zici că ar fi de la telescop atunci?
rulmentul scoate un zgomot scurt, metalic, ca si cand se rupe ceva, mai ales la virare pe loc sau cu viteza f mica.
peste gropi/denivelari aveam si eu, suna urat de tot, ca rulmentul, am schimbat si tot se auzea. am gasit ca se agata arcul in protectia de plastic la compresie....plm.
la del sol nu este rulment sus din cate imi amintesc. am dedus ca se roteste tija telescopului.
Asta parcă se rupe ceva. Sâmbătă am trecut peste o trecere de pod ( crăpătura de dilatare) și s-a simțit de parcă s-ar fi rupt toată de față.
E încă în garanție dar vreau să mă asigur că schimbă ăia ce trebuie când o duc.
sa nu incerci sa demontezi rulmentul sa vezi daca e ok. aparent nu gasesti nimic aiurea. nu rezolvi decat cu schimbul. am incercat eu sa vad, sa gresez....m-am ales cu 5-6 demontari aiurea.
Am fost astazi cu masina la garaj. Au urcat-o de 3 ori pe rampa, au strans si verificat tot dar tot suna. Ultima data m-au invitat si pe mine in garaj. Tot ciocaneau cu un ciocan de cauciuc in componente pe sub masina sa gaseasca sursa zgomotului. I-am intrebat daca au verificat caseta de directie, atunci a lovit ala cu ciocanul in bileta si s-a auzit. Deci se pare ca e ceva in caseta care face zgomotul ala cand se misca bieleta sus jos.
Stie cineva ce bucse sunt in caseta? Incerc sa gasesc pe net piese dar nu prea am noroc.
Powered By MyBB, © 2002-2021 MyBB Group.
HondaTalk.ro © 2010-2021 - All Rights Reserved.
