andrei_r
Thanks Received: 8 in 7 posts
Thanks Given: 9
N-am vazut sa scrie nimic despre putere/cuplu!?
M-as mira sa-l ia direct de pe masina de WTCC si sa-l arunce in TYPE-R, da' probabil ca va fi acelasi motor putintel castrat. Numa' bun de modificat dupa
03-08-2012, 13:50
(This post was last modified: 03-08-2012, 13:51 by kinky_boy.)
Tiago Monteiro tests new Honda Civic at Vallelunga
Tiago Monteiro tested the new Honda Civic S2000 at Vallelunga, Italy, yesterday. The Portuguese driver will take part in the last three rounds of the FIA World Touring Car Championship 2012 season for the Japanese manufacturer, and will be joined by Gabriele Tarquini next season.
Italian website stopandgo.tv reports that JAS Motorsport and Monteiro focused on reliability tests, before starting to work on the setup of the new Honda WTCC challenger.
The former Grand Prix driver will continue to test the car ahead of its debut at Suzuka, and will continue to compete at the next round at the Sonoma Raceway, USA with his SR León before switching over for the final three rounds.
http://www.touringcartimes.com/article.php?id=7920
05-08-2012, 12:42
(This post was last modified: 05-08-2012, 12:47 by Tomi.)
masinile sunt la 20 km de mine dar JAS sunt invizibili in Italia.
...totusi nu va fi o echipa de uzina, tipic Honda
streamul lui yula arata mai sportiv din profil
27-08-2012, 17:45
(This post was last modified: 27-08-2012, 18:05 by kinky_boy.)
un articol foarte fain in speedhunters despre hondele din btcc, poze detalii tehnice fain, merita citit:
http://www.speedhunters.com/2012/08/car-...nda-civic/
Engine
Type R engine, 1998cc modified by Neal Brown Engineering to run a turbo, Garrett based Owen Developments turbo, Omega pistons, standard valves, modified cam, standard crank, ECU Pectel SQ6
Boost – o.6bar over atmosphere which gives 330bhp, peak power @ 6400rpm, 290lbs ft @ approx 5000rpm
Transmission
AP twin plate carbon, XTRAC plate type differential (externally adjustable), Team Dynamics made shifter, hubs are control part, XTRAC control drive shafts
Suspension
Double wishbone, rocker, Penske damper, own design progressive front spring, linear Eibach rear springs, double wishbone with a rocker, Penske damper
Brakes
AP six pot front and two pot rear calipers, 368mm and 285mm discs
Wheels and tyres
10x18in Team Dynamics, control wheel, Dunlop tyres to suit conditions
Interior
Separate AP pedal box with pull type cylinders, electronic power steering, Cobra Ultralite seat with Schroth harness
si doua filmulete cu bataliile si nesimtirile din btcc
de la ultima cursa:
http://www.youtube.com/watch?feature=pla...eCVJ3HFkb0
de la o cursa mai veche (Potato ala e cel mai nesimit pilot ever)
http://www.youtube.com/watch?feature=pla...qNtQsIa2Nw
Nea Cartof ala este si la emisiunea Fifth Gear.
Se joaca murdar in BTCC. Mai sunt cate filmulete in threadul asta cu bataliile date intre ei.
Sent from my GT-I9000 using Tapatalk 2
Ce jeg de pilot...LOL
Sent from my HTC Desire S using Tapatalk 2
Da fac, unde-i finalu de cursa
19-10-2012, 15:49
(This post was last modified: 19-10-2012, 16:24 by kinky_boy.)
weekendul asta e cursa de wtcc la Suzuka cu participare honda
la noi se poate vedea pe Eurosport, prin alte tari nush
Weekendul ne aduce și o nouă etapă din Campionatul Mondial de Turisme. Este vorba despre runda de la Suzuka, a 10-a din WTCC. Yvan Muller este lider al ierarhiei generale înainte de etapa niponă, francezul fiind la egalitate de puncte cu britanicul Rob Huff. Alain Menu este pe ultima treapta a podiumului. Sezonul din WTCC mai cuprinde 3 runde: Suzuka, Shanghai și Macau. Transmisiunile din Japonia încep sâmbătă la 9.30 și duminică la 8.15.
programul eurosport romania: http://tv.eurosport.ro/tvschedule.shtml
nice save from Shedden
http://www.youtube.com/watch?feature=pla...BAeALk8moo
cursa 2 si linkurile la celelalte de curse pe youtube la descriere:
http://www.youtube.com/watch?v=MCkXQb14A...re=related
duminica poate se suprapune cu motogp.
Prea dimineata pentru mine
Sent from my Slimed i9000
vazut vazut
Am prins si io putin da am plecat la munca
am vazut si cursele, pacat ca suzuka nu permite depasiri ca altfel ar fi fost si ceva spectacol.
honda facut 3 puncte in etapa asta  foarte bine pentru prima cursa zic eu, masina a mers bine si a facut fata cu brio in fata seat si bmw
cruze-urile de uzina zici ca-s din alt film, diferenta seminificativa fata de restu care nu prea pot sa tina pasul
cica intra si ford cu focus la anu
