Random Honda's
#61
Honde de la TAS 2012
[Image: AY0F1459.jpg]
[Image: IMG_0080.jpg]
[Image: AY0F1881.jpg]
[Image: AY0F2612.jpg]
Honde in parcare la TAS
[Image: IMG_0001.jpg]
[Image: IMG_0004.jpg]
[Image: AY0F3051.jpg]
[Image: IMG_0017.jpg]
[Image: AY0F3062.jpg]
[Image: AY0F3086.jpg]
[Image: IMG_0002.jpg]
[Image: IMG_0007.jpg]
[Image: IMG_0008.jpg]
[Image: IMG_0032.jpg]
[Image: 112.jpg]
[Image: img_9160.png]
[Image: img_9231.png]
[Image: img_9188.png]
[Image: DSC_0729.jpg]
[Image: DSC_0832.jpg]
[Image: DSC_0834.jpg]
[Image: DSC_0774.jpg]
Clean, clean, clean...
[Image: ?mmid=b2d5dfe53618fe4e9]
Biggthumpup
una curata fara turturi ca mea Icon_smile
[Image: 87220114.jpg]
[Image: 71596398.jpg]
[Image: 32400062.jpg]
[Image: 34310125.jpg]
[Image: 30581402.jpg]
[Image: 65232086.jpg]
[Image: 25319929.jpg]
[Image: 42143437.jpg]
[Image: 74607300.jpg]
dude-ul asta nu si-a pus papucii invers ? Icon_biggrin
ba da Icon_smile
bizarii astia din GB, daca au volanul pus pe dos, au impresia ca totul la masina trebuie sa fie invers Icon_biggrin
Poate ca merge mult cu spatele Icon_smile
interesting pictures Icon_smile
de unde o veni acest V8 ? Icon_smile
[Image: mugenv8.jpg]
niste poze btcc - un ipad pt sofer, un rezervor chiar in spatele scaunului Icon_smile si alte prostioare pe acolo
[Image: btcc12021702.jpg].
[Image: 419851_295682607156839_155336084524826_7...6811_n.jpg]
[Image: 423657_216673861762121_147980061964835_4...3090_n.jpg]
K series Insight Icon_biggrin
[Image: --6.JPG]
[Image: --7.JPG]
[Image: --8.JPG]
[Image: --9.JPG]
Clean Civic
[Image: --37.JPG]
[Image: --38.JPG]
[Image: --39.JPG]
[Image: --41.JPG]
[Image: --42.JPG]
New Insight
[Image: --14.JPG]
[Image: --15.JPG]
Insight-ul ala alb e precum o maicuta la un gangbang filipinez cu transexuali Icon_yikesIcon_yikesIcon_yikes
(27-02-2012, 16:04)w33bb0 Wrote: Insight-ul ala alb e precum o maicuta la un gangbang filipinez cu transexuali Icon_yikesIcon_yikesIcon_yikes
LOOOOOOL M-am cracanat de ras RollinglaughRollinglaughRollinglaughRollinglaughRollinglaugh
[Image: 6936058957_0464ac42a6_b.jpg]
[Image: DSC00027.jpg]
[Image: 6789946332_e41a32663c_b.jpg]
[Image: 6789973636_ac08f3a9e8_b.jpg][Image: 6936089813_7ee40c25db_b.jpg]
[Image: 6936066587_766fd5b59c_b.jpg]
[Image: DSC00026.jpg]
[Image: mimg5121if3mn5.jpg]
[Image: htup_0709_01_z+2002_honda_civic_si+side_view.jpg]
[Image: mdsc02868ms6.jpg]
[Image: m1dsc032001bvwt6.jpg]
[Image: m1dsc00958eb3.jpg]
[Image: m1img7192wo7.jpg]
[Image: 21mc9pe.jpg]
[Image: dsc0892jo3.jpg]
[Image: 188906_1966694166377_1213612318_32503727_6330574_n.jpg]
[Image: 200575_1966691166302_1213612318_32503724_3913499_n.jpg]
[Image: 196600_1966700446534_1213612318_32503740_4496219_n.jpg]
[Image: 197345_1968029039748_1213612318_32506267_3002538_n.jpg]
[Image: 197615_1984033279844_1213612318_32534880_1605149_n.jpg]
[Image: 419353_3542023948637_1213612318_33727616...5405_n.jpg]
[Image: 408915_3453676219999_1213612318_33685856...1140_n.jpg]
[Image: 424428_10150584295297517_652382516_93492...0081_n.jpg]
  • LIVIU_CTS
200CP la roata NA...
Performance – Engine – B20 VTEC
B20 Block - Honed (0.5mm overbore)
Balanced B20 Crankshaft
Golden Eagle B20 Crank Girdle
RS Machine 84.5mm Pistons - 11.5:1
Blueprint H-Beam Rods
ACL Bearings
ARP Main Stud kit
ARP Head Studs
ARP 2000 Rod Bolts
Golden Eagle VTEC Conversion kit
Golden Eagle 84.5mm head gasket
OEM ITR Oil Pump
OEM ITR Water Pump
OEM ITR Timing Belt Kit
Competition Clutch Lightweight Flywheel
Baffled ITR Oil Sump
ITR Oil pickup and windage tray
JDM EK9 N1 Crank Pulley
Ported and Polished B18C-R Head
OEM Honda Stem Seals
Crower Stage 3 cams
Crower Valve springs
Crower titanium retainers
Buddy Club Adjustable Cam gears
Hondata Insulating Intake Manifold Gasket
Edelbrock Victor X Inlet manifold ported to 70mm
OMNI Power 70mm Throttle body
Blox Max-flo 4-2-2-1 (Tri-Y) Header – Heatwrapped
Custom Prospeed 3" Manifold back Exhaust
AEM Hybrid Intake
BPI Velocity Stack & K&N Filter
345cc Injectors
AEM FPR
Rywire OBD0 - OBD1 Conversion Harness with lambda sensor extension
Rywire OBD0 - OBD2 Distributor convertor
OBD2 Dizzy
OBD1 ECU mapped with Neptune
Custom Crankcase breather setup
Precision Oil Catch tanks with breathers
NGK Platinum Plugs
Magnecor KV-85 ignition leads
Custom Earth leads
[Image: B20Map.jpg]
[Image: DSCF8123.jpg]
[Image: DSCF8135.jpg]
[Image: DSCF8177.jpg]
[Image: DSCF8236.jpg]
http://www.youtube.com/watch?v=DfOlEEGkuGQ
deci....bombă!
[Image: d4b78052-0749-71db.jpg]
[Image: d4b78052-0737-b2fd.jpg]
[Image: d4b78052-072a-f837.jpg]
[Image: d4b78052-06c3-9b60.jpg]
una si cu aripioara Icon_smile
[Image: 302263_268208763212057_263457867020480_9...6225_n.jpg]
Powered By MyBB, © 2002-2025 MyBB Group.
HondaTalk.ro © 2010-2025 - All Rights Reserved.
