alaturi de Sodemo , Pipo (Franta) face cam tot ce misca in rally
http://www.pipo-moteurs.com/en/
PIPO Moteurs is installed on a plot of 10,000 m2. Offices and workshops occupy a covered surface of 1500 m2 fully air-conditioned .
Staffing
PIPO Motors currently employs twenty people : engineers, designers,skilled technicians and mechanics. These are all working in perfect harmony, with autonomy and synergy.
Material resources
To be able to continuously satisfy its customers at all levels of performance, PIPO Moteurs met the following hardware resources :
Bureau d'Etudes
CATIA V5 (Dassault Systèmes) workstations for 2D and 3D design, surface or solid , finite elements.
Calculation software : camshafts, mechanical efficiency , etc. .
Physical measurements
Universal metrology equipment .
Machine control BROWN & SHARPE dimensional MicroXcel 765
TESA HITE column , 600 mm stroke .
Laser engraving machine SISMA
Various machines : springs tare, rods squaring, injectors control, etc. .
Flow bench
SUPERFLOW bench , ProBench SF- 1020.
Permeability measurement , swirl and tumble .
Engine test benches
Four cells with Borghi - SAVERI eddy current dynos :
One cell equipped with a single rotors dyno SD - 600 (13 500 rpm ; 600 hp).
One cell equipped with a single rotors dyno FE 600-SDPV (12 000 rpm ; 650 hp)
Three cells with brakes 350 -S single rotor (8500 rpm ; 350 hp)
Each test cell is adjacent to a room where independent control are combined electronic racks control and regulation. Computer equipment to realize the visualization, monitoring and recording of various engine parameters ( temperatures, pressures, oil and water flow rates , etc. . ) In fully automated testing.
Software behavior and control test bench Morphée from D2T.
Magneti Marelli acquisition data software
Pi Research acquisition data software
Means of measuring and recording of each test bed are complemented by a series of portable measurement, including :
Kistler cylinder pressure measurement
Digital storage oscilloscopes .
Timing and organs test bench
Issued from F1, it can drive an engine camshaft mounted in a cylinder head or a complete engine up to 20000rpm
Water and oil temperatures are controled to allow tests under real conditions.
Machine Shop
Seats valve machining tool SERDI Millenium3
Grinding machine and surfacing heads SERDI 1000 -GP
Three valves grains grinding machines PMD model ML -100
Tappets lathe SCHAUBLIN 70 with special machining head
Conventional machine tools : lathes, milling machines, drill presses
Welders FAS 350 and Thyrinertal Samfig 220 -BL
Pipo Moteurs: +33 (0)475 402 202. 41 rue, des Trémolets 07500 Guilherand-Granges (FRANCE).WRCContactPolicy
