mai asteapta ca e prea devreme, le schimbi la anu  NGK-urile standard sunt ce trebuie si pret bun la adilau pe celalalt forum.
How long will my iridium spark plugs last?
A traditional iridium plug such as a ZFR6FIX-11 has an iridium center electrode, however the ground electrode is the traditional nickel construction. The ground electrode will wear out first. The manufacturers of Irdium plugs are saying 40,000 to 60,000 miles. But they have to temper their projections as driving conditions and motor modifications differ. Typically we have found you can expect 60,000 to 80,000 miles on an unaltered motor. (One of our trucks has had the Denso's in for 76,000 miles. We examined 2 of the plugs, they had some minor spooning on the ground electrode. Put them back in and will likely change them in another 5,000 miles.)
Some NGK iridium racing plugs have iridium center and a platinum ground electrodes. If installed to a regular engine they would likely last longer than most people keep their car (barring any motor problems that can cause premature plug death). But, these usually come in heat ranges too cold for an unaltered motor, and are usually used in racing applications where all bets are off.
For the traditional automotive market, the longest lasting plugs are the NGK "IFR" series. These have iridium center and platinum tipped ground electrodes, however these are extremely limited in application as they only manufactured these in a couple of heat range configurations.
No masina a iesit din garantie, cu ocazia asta e la Asko de vreo 2-3 sapt pentru o verificare generala, am rezolvat si lovitura de la usa din dreapta de vara trecuta, am mai 2 cupspoilere verzi ptr ca erau lovite un pic, am montat si garnitura Hondata la galeria de admisie, am pus un kit bluetooth original Honda ptr telefon si s-ar putea sa pun maine si o evacuare, sa vedem cum ma inteleg cu buzunaru
Colegu razvan, daca sunteti prin zona si disponibil la o poveste mica va stau la dispozitie, la fel domnu coleg Weeboo  .
Pai zi-mi o zi si o ora, ca sa iti pot spune daca sunt disponibil
Pai ne auzim, stau mai mult prin capitala.
pai sa ne auzim atunci, da vb lui weebo sa zici cam cand esti la plimbare si ai timp
adi de unde ti-ai luat ganitura de ai pus-o la admisie? ca as vrea si eu una da o hondata noua mi se pare exgerat de scumpa, cel putin in uk
Mie mi-a adus-o Alex de la ZzTuning, vreo 300 si ceva de lei parca a fost.
Cand dai comanda in UK zi si mie, mi-as lua si io piulite  .
pai zilele astea o sa dau comanda, cand lamuresc cu tipul ala legat de bucsi o sa dau si comanda, te sun inainte si daca esti hotarat imi zici.Vezi linku de la mine si daca e alegeti de acolo.
06-03-2012, 15:43
(This post was last modified: 06-03-2012, 16:14 by DeN1gRator.)
Foarte fain! Si eu am problema asta cu mansonul.
auzi, cand vii la cj, te prezinti pe la mine cu o bucata, ne-am inteles? da cu cusatura gri-argintiu ca la type-s
Trebuie sa intri in business acuma
arata bine, vb lu yula apuca-te de business  ...
al meu e de caucic si nu o sa moara niciodata, vezi inca ceva pt care ep3-ul e mai bun  ... schimb-o !!!
sa-i fie de bine! da nush ce ti-o venit cu bling blingu ala de capac
arata bine :d tre sa iau si eu husa daca ii dau cu spray
Sunt covorase alea ca nu vad bine pe telefon?
Esti 50cent mah cu capacul ala
Hai hui
taceti bah odata, vreti sa ii confunde cineva fn2-u cu fn1?
lasa bah, tu sa fi sanatos, las ca bat eu bendixu de tine cand te vad
Trimite-l inapoi si zile ca nu e ca ala din poza.
Hai hui
