12-01-2013, 01:36 (This post was last modified: 12-01-2013, 13:44 by yulasinio.)
Versiunea de aplicatie 2.4.8
Code:
What's in this version:
version 2.4.8
- Bug fixes
version 2.4.7
- Fixed shortcut issue
version 2.4.6
- Bug Fixes
- More Language support
version 2.4.5
- Fixed some forum failed to connect issue
Version 2.4.4
- Fixed Empty Favorites Forum issue
- Fixed "New Topic" Menu no effect issue
- Other Bug fixes
Updatat plugin-ul Tapatalk, daca exista probleme va rog sa le reportati.
Code:
Version 3.3.2 released
Update note:
1. Add read only control based on forum ID.
3. Add register function (need app side support)
4. Add separate detect display words from js .
5. Add "newtopic , quote , @tag" function for push .
6. Add Thread Content Replacement (Advanced) function .
7. Add rename topic title function (need app side support).
8. Add Smart Banner on Android Tablets .
9. Add multi-quote support function.
10. Fixed a potential SQL injection issue.
11. Fix SQL error when pm's tittle include " ' " character .
12. Fix Embedded not displaying after upgraded .
13. Fix quote text do not display on iOS device .
14. Fix SQL error with push function when post contains certain contents.
15. Optimize Display Text for Online Tapatalk User .
16. Optimize online user list display
17. Enhance attachment type .
18. some minor bugs fix .
Instruction for @ tag function for push:
You can mention someone when you are posting by add text with "@username" format(There should be no character directly before @).
Example:
There are some words in A's post:"I did remember @B , he is a good guy!"
If you enabled push notification in app, you will get a push data like "A mentioned you in thread '....' ".
What's New
v1.4.x
- Works for both phone and tablets
- Bug fixes
v 1.3.x
- Tapatalk ID now upgraded with Facebook, Twitter and Google accounts sign-in support
- Full screen image viewer improvement
- Push notification improvement on Jelly bean
- Fixed category can not be subscribed issue.
- Other issues and crashes fixes.
v 1.2.x
- Fixed lunch crash issue
- Fixed empty post issue
v 1.2.2
- Fixed image upload crash
17-08-2013, 18:03 (This post was last modified: 17-08-2013, 18:06 by danylson.)
Acesta este noul format ?Am actualizat aplicatia si au schimbat tot formatul , am cautat in App Store , dar nu vad nimic de tapatalk 4. Cum il pot descarca direct dupa telefon?
Eu tocmai l-am pus pe iPad si iPhone. Spun ca cica a devenit gratuit. A fost un simplu upgrade, ca in cazul multor altor aplicatii. E... meh... mai dotat, da' parca mai peste mana. Cre' ca tre' sa ma obisnuiesc cu el.
Eibach · OMP · Summit · DIMSPORT · Injen · Megan Racing · Custom 5h1t 2003 VFR800 Interceptor 1994 CRX del Sol EH6 - SOLD!
