De ce piese aveti nevoie!?
Jantele alea sunt de... cat? Icon_smile
215.45.17 scrie pe caucioace
2 x 17x114.3 + 50 7.5J
2 x 17x114.3 +42 8.5J
Hmmm... Mai ca ma roade un gand... Icon_smile
Sunt ca si noi, fara zgarieturi sau altceva. Totusi as oferi un pret mai mic, poate musca Icon_smile
un prieten bun vinde tot, a rupt o biela la doar 1400 dupa ce a armat motorul
CRX Ed9 1991
Km sasiu 120000 Aprox.
Km Motor 1400 Aprox
suporti swap Hasport
timonerie swap Hasport
conversie cablu-hydro Hasport
conversie Obd0-Obd1 ECU, delco si senzori
Hondata S300
ECU P30 Chip
ECU P28 Chip
Suspensie TEIN Type HA
Cutie S80+LSD OEM ITR
Volant Motor Fidanza
Ambreiaj ACT Clutch 6 pads 200km de uz
header Tegiwa 4.2.1
Esapament Duramas
Regulatoare de cadere fata Skunk2
Swap frane 282mm
discuri Galfer
Ferodo DS2500
furtunase Goodridge
Lichid de frana Ferodo 5.1
pompa de frana OEM cu 30k km
pompa de benzina Walbro
Regulator presiune benzina 12Tune
Injectoare RC 310cc
Swap ITR JDM Cluster (180km/h)
Volan OMP Corsica 350mm deplasat
Pedale Mugen
Kit silentblock poliuretan Powerflex
Bara superioara OMP
Bari interioare spate EM-Racing
Backet Sparco Pro 2000
2 scaune OEM
2 centuri OMP 6 puncte
Jante Braid Winrace TA albe 15x7 Et20 + R888 la 30% fata y 70% spate
Jante MIM Oldschool + R888 la 40%
2 Toyo R888 la 50%
2 Toyo R1R lal 80%
baterie in portbagaj
goala in spate si fata partial
Dezmochetata
Bloc B18c6
vibrochen OEM
Biele OEM
pompa de ulei OEM
cuzineti Clevite
Surubaraie ARP vibrochen, biele, chiulasa
Kit de garnituri Cometic
Kit de distributie OEM
Rectificat camasi
Pistoane Wiseco +0.5
Carter Spoon
culata B18c6
Came Brian Crower Stage 1
supape Brian Crower
arcuri supape duble Brian Crower
semeringuri de supapa Brian Crower
ghidaje supape cupru
role relglabile Fidanza
http://imgur.com/a/N10C2/embed#0
http://imgur.com/a/YyTAi/embed#0
pret: 7500€
Se risca cineva?
Quote:full engine and gearbox out of my ep3 with around 100k on the clock
3rd gear has slight crunch like most do but all other gears are perfect
engine has a bit of bottom end damage, spun a bearing on the crankshaft but mostly bearing damage so crankshaft is barely marked
500 euro for both engine and box
Kpro n-are?
are si ecu? si restul de maţaraie?
Nu are ECU sau cabluri, e numai motorul si cutia
pacat
Am facut rost de cartea de vizita a firmei de curiereat. Nu e reclama, vreau doar sa ajut! Stiu ca trasporta chestii grele cum ar fi motoare etc.
Dublin: 00353-879841237
Romania: 0040-721228856
Sti cumva ce firma ii si ce pret practica, cunosc si eu cateva dar toate practica acelasi pret.
Sent from my GT-P7510 using Tapatalk
Laux, daca au si-un site e perfect.
Bineinteles ca nu-i reclama Icon_smile
Alfredo Transport si Curierat Rapid sunt romani si au sediu in Germania, doar trei numere de telefon si un e-mail gasesc pe cartea de vizita: "alfi.holl@web.de" , mai multe nu stiu, trebuie intrebat. Cam cate kg are un B18 de exemplu !? ca sa intreb de un pret aproximativ.
Cu Alfredo am trimis si eu pana acuma pachete Icon_wink Sunt foarte buni si nu am avut probleme niciodata cu ei dar sa trimiti un motor nu este ieftin pentru ca taxeaza cu 1,80€/kg. Dau ceva reducere daca ai peste 100kg dar nu mai stiu exact cat.
ca informatie, nu stiu cat de mult poate sa ajute dar ca idee:
tovarasul meu Cata a trimis de aici `prin Barsani un swap complet B16a2, luat de acasa si dus in Ro -150 €
acum am si eu nevoie de stickere ca mi-am zgariat lip-ul din fata si cu ocazia asta l-as decora , de Six Performance nuts pentru jenti stiti ceva ? calitate si greu de gasit la pret bun ? eu am un pret de 104 € si nu ma prea incanta ...
Stickere sunt pe net cate vrei, daca ai carte de credit poti sa le cumperi. Ai grija ce piulite iei la jante ca a tale sunt OEM si iti trebuie sa aiba forma rotunda unde face contact cu janta.
Sincer eu as sta cu piulitele alea OEM decat sa cumpar ceva cu care o sa am probleme pe viitor.
se gases adaptoare la tegiwa pentru piulute aftermarket si jante stock.
http://www.tegiwaimports.com/alloy-wheel...ptors-392/
