17-01-2011, 23:02
(This post was last modified: 27-02-2011, 12:33 by LauX_LauX_LauX.)
AEM TRU-TIME Adjustable Cam Gears increase horsepower and torque without having to change the camshaft(s) and are must-have items for engines that are milled, forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and AEM's anodizing on the gear teeth is lab-test proven as the hardest anodizing process on the market.
AEM TRU-TIME Adjustable Cam Gears are available in a multi-spoke, five-bolt design for most vehicles and our classic full-faced, three-bolt design for select applications. Five-bolt cam gears have an “8” in the suffix (23-8XX), and three-bolt cam gears have a “6” in the suffix (23-6XX).
•Increase horsepower and torque without any cam changes and are ideal for heavily modified engines
•Grade-8, six-point hex bolts stand up to repeated adjustments and feature an integral washer flange for greater load distribution
•True laser-etched markings on the leading edge of the gear allow for quick, accurate adjustments
•Hard anodizing on belt surface is lab-tested as the most durable anodizing on the market
•CNC-machined from 6061-T6 billet aluminum
•Comprehensive installation instructions, recommended cam gear settings and decals included
•Manufactured and assembled in the USA
•For Off-Road use only
SKUNK2 Pro-Series cam gears feature a super lightweight design and are CNC machined from 7075-T6 billet aluminum. Each gear has laser etched timing marks with +/-10 cam degrees of adjustment and feature Skunk2’s proven 6-bolt design. The outer gear is hard anodized for durability and the center hub is Titanium anodized for that racing look. Pro- Series cam gears are 5% lighter than our already ultra-lightweight Tuner Series cam gears.
•CNC Machined 7075 Aluminum
•Hard Anodized Outer Gear
•Industry Leading 6-Bolt Design
•+/- 10 Cam Degrees of Adjustment
•35% Lighter Than Factory Gears
•5% Lighter Than S2 Tuner Series
TODA Racing campulleys allow precise tuning of camshaft timing. Adjustable campulleys are essential when using Toda Camshafts or any non-stock performance camshaft. TODA campulleys are made completely from 7075 aluminum while our competitors use 6061. 6061 is a cheaper grade of aluminum and is easier to produce on CNC machines, therefore is cheaper to produce. 7075 is a more expensive and higher grade of aluminum commonly found on fighter aircraft landing gear or other high stress areas. The use of 7075 aluminum allows TODA Racing to offer the strongest and lightest campulley on the market. In addition, our advanced timing degree system makes TODA campulleys the most accurate on the market. For long term durability the timing marks are machined into the metal, not painted on, or silk screened, therefore they will not rub off with age.
Some aftermarket campulleys use connecting bolts that are not compatible with TODA camshafts. The use of these bolts could damage the TODA camshafts. If you plan to use TODA camshafts, Toda only recommend using TODA campulleys to prevent damage to the camshafts.
HKS Adjustable Cam Gears allow fine tuning of the camshaft timing to maximize engine performance and tailor power characteristics for various driving conditions. Either with OEM or HKS Camshafts, adjustments can be made to tune an engine’s power band to the optimum RPM range for a particular application.
HKS Cam Gears are made completely of anodized Duralumin with nickle plated gear teeth except for applications with timing chains which utilize an aluminum slide with steel teeth. HKS engineers chose Duralumin as the core material for HKS Cam Gears because its lightweight properties decrease drag on the engine.
Precise valve timing can be adjusted and set within the range of ± 20° along a Vernier scale of 2° intervals. Each interval index is laser-etched into the Duralumin and "A" (advance) and "R" (retard) directional markers are also laser-etched on to the cam gear face.
OBX Precision Adjustable Cam Sprockets are a wonderful method of extracting extra power from an engine. Adjustable +/- 10 degrees, these sprockets allow the user to tune the engine for more power in low, middle or upper RPM ranges. This adjustment allows the tuner to move the peak power along the engines natural power band by advancing or retarding the cam timing.
CAD designed and CNC machined from 6061-T6 aircraft grade aluminum, the adjustable cam sprockets are extremely lightweight yet able to withstand extreme abuse. The hard baked gear teeth prevent wear and tear and our advanced 5 point locking design keep belt slippage from occurring.
OBX Precision Adjustable Cam Sprockets are a great way to dress up an engine and at the same time tunable to reach an engines true potential.
•CAD designed and CNC machined from lightweight 6061-T6 billet aluminum
•Advanced 5-bolt pattern to eliminate change of cam gear timing
•Allows for single degree adjustment to a maximum of +/- 10 degrees (advance/retard)
•Laser cut degree marks for easy reading and adjustment
•Hard-baked gears teeth prevent wear under the toughest conditions
Fidanza. The camshaft is the one part of your vehicle that determines the timing of the critical events that result in the production of horsepower. While amazing improvements have been made in the ability of the internal combustion engine to produce horsepower, the camshaft is largely unchanged in the history of the 4-cycle motor. Fortunately, this doesn't mean you are stuck with what you have! Most camshafts are designed so that they open and close the valves to ensure both fuel economy and reliability. With Fidanza Adjustable Cam Gears, you can realize improved torque or increased horsepower without sacrificing reliability.
Consider these benefits:
•6061 T6 Aluminum construction
•CNC machined to more exacting tolerances than original gears
•Beveled tooth edges to increast belt life
•12 Degrees of laser-etched adjustment
•Stainless steel fasteners
BLOX Racing adjustable cam sprockets allow performance enthusiasts and engine tuners to adjust intake and exhaust camshaft timing for optimal horsepower and torque and efficiency.
